5800x3D 'overclocking' results.
Increasing the max boost clocks generally doesn't do anything. Look at effective clocks in HWInfo and it likely won't show clock increases.
Bumping from 4550 to 4650 did seem to make a small difference on CB MC scores, and showed aprox 25 higher boost across all cores while running.
12+ hrs prime 95 @ -30 +200 boost.
Tomorrow I'll see if there's any room on these super cheap ram sticks, but I'm not holding out any hope of being able to tighten them.... they're binned crazy loose to do 3600. (18-22-22-42)
edit: Interestingly, AMD's Adrenalin control panel recognizes the +200 boost clock set in bios. Not sure if that's a function of having Ryzen Master installed or not (I intend to uninstall Ryzen Master now that I've got the CO settings from it)
