Black Myth: Wukong Benchmark Tool
sswilson
Moncton NB
New benchmark released in advance of the game to see if your hardware is up to the task.
Haven't tried it with my 6800XT @ 1440p yet, but the default settings on my 4070 4060 (I blame the covid :) ) laptop seem decent enough, but that's with DLSS enabled. (Going to try it with DLSS off to see how much of a Hit I take).
edit: Nope, unless I'm missing something there doesn't appear to be any option to change the default settings it spits out.
I haven't tried it yet, but it appears to have a looping function if you want to use it for stress testing.
So I played around with this a bit and these are the results.
Machine specs:
7800X3D
MSI 4090
32GB 6000MHz ddr5
Benchmark installed on pci4 nvme
Settings that never changed:
borderless full screen at 3440x1440
All quality settings at cinematic
motion blur - strong
Full Ray Tracing set to very high
Run 1:
DLSS = 100 aka DLAA
Frame Gen = Off
Avg: 37fps
Max: 44fps
Min: 27fps
Low 5th: 32fps
VRAM: 9.3 GB
Run 2:
DLSS = 100 aka DLAA
Frame Gen = On
Avg: 66fps
Max: 78fps
Min: 55fps
Low 5th: 58fps
VRAM: 9.9 GB
Run 3:
DLSS = 75 aka Quality
Frame Gen = Off
Avg: 63fps
Max: 75fps
Min: 48fps
Low 5th: 54fps
VRAM: 7.9 GB
Run 4:
Frame Gen = On
Avg: 107fps
Max: 129fps
Min: 89fps
Low 5th: 94fps
VRAM: 8.6 GB
Run 5:
DLSS = 60 aka Balanced
Frame Gen = Off
Avg: 73fps
Max: 89fps
Min: 54fps
Low 5th: 62fps
VRAM: 7.4 GB
Run 5:
Frame Gen = On
Avg: 122fps
Max: 147fps
Min: 101fps
Low 5th: 107fps
VRAM: 8.2 GB
How were you changing the DLSS? Is there a setting in the benchmark, or were you using the global driver settings?
All settings done in the benchmark.
They are under settings then graphics then super resolution sampling.
You have options for XeSS, FSR, TSR, and DLSS.
Frame Gen is available on all but XeSS.
The sliding scale goes from 25-100 and is as follows
25-39 Ultra Performance
40-54 Performance
55-61 Balanced
62-89 Quality
90-100 DLAA
yikes what happened with that. i got banned form scamegg for returning the forklift games loser of 2020 when i bought a 5900x that was used in scam eggs forklift hockey ><.
I asked for a refund on one of the Tiger Woods golf games because after trying for 5 or 6 hours I could not get the game to run properly. I went past their 2 hour max and the refund was refused. I charged back through PayPal and they lost.
I've heard this benchmark has issues with texture and object loading. More than one source mentions having to run it 3 or 4 times in a row to see accurate numbers for your setup. I'm currently downloading to test.
