I have been clearing out inventory in the office... 2600k machine I kept only has 1 job running video conferences, on linux because windows is too slow running on it.
Been working on this xbox one pc mod for some time now. It's finally time to post it for sale for someone to enjoy it. This is my first custom pc mod I made from an old xbox I had laying around. Decided I would try a pc mod and turned out better than I expected. I have to say the thermals on this are good for being in such a small case. Very satisfied how it turned out and definitely not something everyone has.
How I designed the gpu to be mounted is the best way possible for cooling. Cut a couple holes in the bottom for the case for fresh air flow. I would recommend getting laptop cooling pad and that would keep it cool while gaming. It's running about 70° to 75° stock while gaming which is normal. The cpu runs about 55° to 60° which is decent. These can be alot better with a cooling pad.
You see in the video of me turning on the pc. I mounted the power switch to the sync button to be hidden and looks original. The main power was not possible to get working with the motherboard. It lights up blue when turned on but thats just indication that the pc started up.
It's fully wifi and Bluetooth with the motherboard used. I have the second best cpu you can have in this motherboard. So their is room for little upgrades in this mod. No issues at all this is my first xbox pc mod so it's not perfect. But it is clean, specs are
- I7 6700K 4-Core 8-Thread Cpu Clocked @ 4.0Ghz *Can be overclocked*
- Asus Rog Strix Z270I Gaming Mini Motherboard
- 16GB DDR4 2733Mhz Dual Channel Ram
- Asus TUF Gaming GTX 1660 Super 6GB Gpu
- Metalfish 500w Flex Psu
- 512GB M.2 SSD
- Windows 10
I would of liked higher end components in the build but unfortunately I have the biggest power supply I can get in flex psu so I had base the parts around that. I think I made the right choice of parts. Great 1080p gaming pc and something nobody else has. I want $600 for this modded pc. I put alot of time effort into this build and I think it should be appreciated. If you have any questions at all please do msg me.
Dropped $950 in 2 months. Only needs to drop another $525 now.This decrepit garbage ain't worth $25 at this point.
And it doesn't even have the CPU fan shrouds. It will overheat in minutes.
