A good mid tower case for lan.
nwa4life
Active member
Singapore
sup. i was wounderin wat a good mid tower is. i lik coolermaster in general but i am open to other brands also. i am looking for a really light case. i would prefer a window and anythin that supports micro atx with at least 4 exp slots (mid towers should have this) basically lik that but really light. i was thinkin of the 690|| but it looks a bit big for carrying coz i want to carry it onto the bus coz i dun have a car. :)
The Corsair Graphite 600T, it's an awesome case with hidden handles and a side panel lock hidden under the removable top grill to protect the hardware inside :thumb:
ahh but i will want to put 2 5970's into the case. wat mid tower case supports such 2 gpu's???
The Scout won't fit those GPU's , I have one and Love it but I believe the 5970's would be too long.
My only other suggestions would be NZXT Panzer Box or Vulcan.
Both of those should do it, but in the Vulcan you would have to remove the front lower HDD holder to make both work.
ST
im only gonna have 1 hdd in there. probs the veloci raptor or something small. its just for lannin and its in between a hdd and a ssd. so i think i will take a look at that. anymore cases???
Good selection, not all of them will fit the 5970's in tandem though. The Panzer Box has the best cooling for what you're running, as well as the ability to fit a 240mm RAD up top if you wanted to WC it.
ST
