A new build - UK Gaming PC
dtinsley219
New member
It's only purpose will be gaming.
Around £1400 max, this would have to include everything including the monitor.
England
4. IF YOU have a brand preference.
I'm not loyal to any brand, i've always used Intel and Nvidia however.
I have a watercooling loop on my old PC which I will reuse to cool the CPU, I won't cool the GPU initally but plan to do it in the future. This has a 360mm Rad.
Not looked at many threads.
I'd like to overclock the CPU and the GPU if it needs it.
in a couple of months.
9. What resolution and settings do you use?
1080
10. Are there any specific technologies you want?
No
https://uk.pcpartpicker.com/list/4jyKm8
CPU Intel - Core i7-7700K 4.2GHz Quad-Core Processor £322.99
Motherboard Gigabyte - GA-Z270X-Ultra Gaming ATX LGA1151 Motherboard £139.99
Memory Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory £129.49
Storage Western Digital - Black PCIe 256GB M.2-2280 Solid State Drive £109.49
Western Digital - 3TB 3.5" 7200RPM Internal Hard Drive - I own already
Video Card Asus - GeForce GTX 1060 6GB 6GB Strix Video Card £300.00
Case NZXT - Phantom 530 (White) ATX Full Tower Case £109.99
Power Supply EVGA - SuperNOVA GS (UK) 550W 80+ Gold Certified Fully-Modular ATX Power Supply £74.99
Operating System Microsoft - Windows 10 Home OEM 64-bit £100
Monitor - I'm considering the Iiyama Prolite GE2488 24"
Luay79
I'd choose the Crucial MX300 instead of the WD Black SSD. Can't comment on the case but I like the Fractal Design C.
You can get away with a smaller video card. Your target of 60fps @ 1080P is within reach of the smaller 1050ti for most games. I reckon you're saving up for a big card and monitor for later?
Otherwise, sorry to say so, you don't pay for an i7 and slap a GTX 1060 on it and call it a gaming rig.
Bond007
Nova Scotia
My thoughts:
It will definitely be a nice build, but there are some things I would change.
1. The EVGA G3 is probably a better PSU (not that there is anything wrong with the one you picked). Pretty much the same price
https://uk.pcpartpicker.com/product...fully-modular-atx-power-supply-220-g3-0550-y3
2. Case - I am not a fan of that case at all, but it is a personal choice
3. For minimal extra cost you can get this 525GB SSD:
https://uk.pcpartpicker.com/product...25gb-m2-2280-solid-state-drive-ct525mx300ssd4
otherwise save a bit and get this 275GB:
https://uk.pcpartpicker.com/product...75gb-m2-2280-solid-state-drive-ct275mx300ssd4
frontier204
ON, Canada
No issues from what I see, although you probably won't notice DDR4-3000 versus DDR4-2667 or DDR4-2400 in 1080P gaming on a dedicated GPU. That said you probably will take a performance hit if you drop all the way to DDR4-2133 or less.
Only get the DDR4-3000 memory if it happens to be on sale for the same price as a slower speed, otherwise don't be afraid to drop the speed of the RAM a bit to save money for something else like the monitor or accessories.
Also an EATX full tower will probably look a bit empty with an ATX motherboard, 1 GPU, and 1 3.5" hard drive, even after the water cooling stuff. (That said I used to made 450 gram fighting robots in high school so shoving electronics in and forcing the chassis shut with screws is normal to me. I currently have 4 2.5" hard drives, 1 3.5" hard drive, and a GTX 1080 hybrid cooled stuffed into an Antec P180 mini.)
TouliBoo
New member
From what I see with such budget, I'll go for GTX1070 or GTX1080. Maybe that's the price in the UK
