Signal2Noise
Greetings fellow illustrious Canuckers!
I am hoping some folk here are still in the dark ages when it comes to using the subject Gigabyte mobo (Master version, BIOS f/w F11) or perhaps still remembers some of its nuances after moving on and up in custom PC builds.
I want to add a 2nd NVMe PCIe SSD and planned to throw it into the M2A slot. I do have Win 11 OS loaded onto a Samsung 970 Pro NVMe PCIe SSD in the M2P slot as primary boot drive and has been solid since the initial build 4 years ago. Both M2A and M2P slots are fine when it comes to the sharing, or rather remaining separate, of lanes on the SATA3 ports. I have 4 SATA devices (2X SSD, 1x HDD, 1X ODD) connected, ports 0/3/4/5.
For the second NVMe I first bought a 1 TB Samsung 980 Pro. Intention with it is to use it for specific games (namely Starfield) that require SSD installation. The BIOS (and Win11) does not recognize the SSD when connected. I hunted the googleverse looking for troubleshooting info to no avail. Figuring it might be the SSD itself, I procured a 1 TB WD_Black SN770 today (figured older model would be compatible) and threw that in to the M2M bay. It too is not recognized. So I figure there’s some settings I am missing somewhere in BIOS for it to be detected.
Next steps will be unplugging ALL SATA devices which I think is a tad extreme since ports/lane bandwidth shouldn’t be affected per manual (M2M slot is the most impacted and don’t plan to use). Another suggestion I came across was to remove and replace CMOS battery which I have not tried yet.
Really looking for a solution or some sort of guidance of what can be checked in troubleshooting here.
Thanks for reading and looking forward to suggestions.
Cheers!
Cheers!
