ASUS RT-AC87U & RT-AC3200 Routers Review
ASUS RT-AC3200 Conclusion
The ASUS RT-AC3200 is a study in contrasts. On the one hand it is easily the fastest router we have tested to date. On the other, it is only really fast at short distances and only when taking advantage of its multiple networks. If all that was not enough to muddy the waters, the ASUS RT-AC3200 also has the most potential we have seen in a long while, but only if its underlying tech XStream 'wins' the war. Otherwise it will be simply a very fast router but one that will be always on the wrong side of history. This makes for a solution which will not be right for everyone, and one that may be hard to justify for those who do fall within its obvious design goals it does offer a lot, and maybe even more in the future.
Some of the reasons the ASUS RT-AC3200 is not able to be a slam dunk success for home users is not because we found it wanting in the performance or features department. Rather any areas left wanting are due to the fact that it is not really intended for the typical home consumer environment. Instead this router is geared towards SOHO users and homes with a lot of networked devices. Basically it is a tailor made solution for heavily congested networks, regardless of if XStream becomes widely accepted or not. This means for the average home consumer the ASUS RT-AC3200 will be overkill in the worst possible sense of the word. In fact, most users may not even notice any difference between it and a lower priced “AC1900” solution.
What ASUS has here is a router capable of blowing the doors of the competition but one that is also hampered by its relatively narrow target audience. This is no fault of ASUS since they had to work within the current network standards, of which a faster solution hasn’t been ratified yet. That means unless you have an insanely congested 5GHz network that will benefit from a second seamlessly integrated sibling network, the benefits brought to the table by the AC3200 will be minimal.
As time goes by this situation will change and the ASUS RT-AC3200 will start to shine, but until then its performance will never be as great as its large model number would suggest. This does however explain why ASUS does not consider the AC3200 to be above the AC87U in their product stack. Instead they are meant to coexist and are aimed at slightly different markets.
Thankfully, for those ASUS is hoping to court with this router, it is a stunning success. The RT-AC3200 has an onboard SoC powerful enough to handle multiple heavily used networks, software features that now actually work like they are supposed to and a user-friendly interface that’s literally second to none. Overkill or not the end result is a model with a lot going for it. As long as you can afford it, and think you would benefit from its unique abilities, you will be impressed with what the AC3200 has to offer.
ASUS RT-AC87U Conclusion
We must admit that the ASUS RT-AC87U impressed us more than we thought it would. On the surface, the it would seem to be nothing more than an "also ran", always in the shadow of the AC3200. After all it is missing two external antennas, a third network, and has seemingly lower potential performance. More importantly this unit shows the inherent weakness in the way router performance is classified.
While right now the ASUS RT-AC87U cannot actually meet the performance levels of its sibling nor even meet its own AC2400 rating it consistently posted some of the best numbers we have seen, and actually outperformed the RT-AC3200 at longer distances. Of course if you have heavily congested networks the more expensive of these two solutions will provide better performance thanks to its second 5GHz link, but of if Wave 2 takes off this router may someday actually outperform the AC3200 for the typical home user at <i>all</i> distances.
With that being said the chances of XStream beating Wave 2 are 50/50 and one beating the other before the next generation of routers is out are slim. It will ultimately come down to how fast 4x4 networking adapters can be brought to market, as this is the ace in the hole that Wave 2 has yet to play. Either way we would not choose one over the other based solely on possible <i>future</i> abilities. Basically we have a Beta vs VHS war brewing…and no way of knowing which is Beta and which is VHS until it is all over.
If you need to make a purchase right now the technical abilities of the AC87U are somewhat pared back compared to the tri-band AC3200. However the ASUS RT-AC87U is still one heck of a router even without the razzle dazzle of the 4x4 configuration and at a lower price to boot. That to us makes the ASUS RT-AC87U one heck of a value.
For those who really have to think long and hard about the asking price of the RT-AC3200, the ASUS RT-AC87U makes much more economical sense as it is one of the better values on the market today….and may even get better if 4x4 devices land soon.
<div align="center">
<img src="http://images.hardwarecanucks.com/image/akg/Networking/ASUS_3200/DGV.gif " border="0" alt="" /></div>
