CPU to GPU?
The pump has everything to do with it. As you said, more water will go through the path with less restriction. However, it's not a constant amount of water but a percentage of the water that's moving. The concern in this setup is that the higher-restriction part of the loop won't have enough water moving through it. If your pump moves a lot of water there will still be enough water moving through that it cools the higher-restriction piece.
bla bla bla full dangerous to play with Y .... play a little bit with water kid you will understand ....
computer water pump do not build pressure, they have low head presure , so it will not neccessary do as well as you said.. will certenly not recommended it to a member here.
