DIY Gaming Keypad Worklog
lowfat
Grande Prairie, AB
wow you are crazy. looks great through. what games do you mostly play?
Mostly? Nothing :eek:. I play a handful of games a year. All single player, generally RPGs. Mostly just doing this as a cool project. Also my current Orbweaver is kind of a POS. It prevents my computer from turning off display / going to sleep. And Razer DRM/software sucks.
lowfat
Grande Prairie, AB
LEDs finally showed up not that long ago from China. Finished soldering up the PCBs today.
Installing the PCBs on the back of the switches.
But then..... I somehow screwed up on my measurements. The PCBs long this edge will not fit. I even modeled the PCBs to make sure I'd get the clearance but they are 1-2mm short. :(20200926_141804 (Large).jpg
EDIT: Looking at my 3d model, the switches face the other direction. So maybe I'm not humped after all.
FreeKnight
Edmonton, AB
Impressive work so far lowfat. I had considered an orbweaver years ago, but am not a big fan or Razer quality or their software. I definitely wouldn't have the know how to go this far on making my own though!
lowfat
Grande Prairie, AB
Switches were just installed wrong direction. Was an easy fix. However I didn't have clearances on the frame for the PCBs. Same w/ the thumb cluster. So I reprinted them yesterday.
Test fitting, may still need to extend the wrist rest a tiny bit back.
lowfat
Grande Prairie, AB
Already thinking about going w/ a different design. :eek:
I think w/ an function modifier key I can eliminate at least 10 keys from it. This decreasing size substantially. Also remove the ARGB underglow trim lighting as this feels too tall. I can cut it down by 1cm by removing the LEDs. Thankfully from what I've learned it won't be hard to start over. Only really wasted about $25 in plastic.
lowfat
Grande Prairie, AB
Wanted to be productive but didn't feel like working on 3d printers at the moment. So started on rev 2 of the keypad. Think I'm finished the model. Can't print at the moment as I don't have any printers working capable of printing it.
