First Watercooling Build
My Treibwerk fans are almost silent to me , also the 360 will only be doing the motherboard , but I think you understand now that I am pulling the air up from the bottom of the 800d through the rads and out , as soon as Daz gets my chipset block in I will start pulling everything out ot my Antec 1200 and building it in the corsair (can hardly wait)
Just the beginning
witch one the EK 100 ... it will look to small on the obsidian, take the 250 , I know I order a 150 and it was too small, I have to order a longer tube
EK-Multioption RES 250 multioption EK watercooling loop compensating reservoir [EK-Multioption RES 250] - $45.99 : DazMode, Watercooling enthusiasts store
This is the one I was looking at after you said the EK100 was too small...
[FONT=Verdana, Arial, Helvetica, sans-serif]Ek Water Blocks EK-BAY Spin 5.25IN Bay Reservoir with Flow Meter & Waterfall - Acetal
( NCIX.com - Buy Ek Water Blocks EK-BAY Spin 5.25IN Bay Reservoir with Flow Meter & Waterfall - Acetal - 3830046994233 In Canada. )
[/FONT]
do you have the 88 cfm or the lower one ?
I have the 121 's right now but I will probably order the 122's before I build , I did a lot of searching and because of the body design these should work very well plus I havent seen any other fans with this low sound ratings to cfm output .
ok your run at 1200 rpm and mine a 1800, that explain the difference in the noise, I have to buy a fan controler for them, or i will plug them on the motherboard
I have ordered the Rheobus 6 fan controller from Daz for now ,I think it will be a better bet than the motherboard connections . Did you run the fans mounted on the rad or loose ?
