Want to Buy Mini PC
supaflyx3
Langley, BC
Hi all, looking for a mini PC to run proxmox on.
Looking for something like an N100/N150 or a Ryzen 4*00u or 5*00u that uses ddr4. Thanks!
A while ago I bought a bunch of mini PCs and split a bunch of them off. I kept 3 Lenovo p320 tinys which have a 6700T and quadro p400 or p600 can't recall which right now. More capable than the n100 but a bit more power hungry especially with the dedicated GPU.
I originally had plans for all 3 but it has been reduced to just 2.
I already have a big power hungry 4u server in my lab with a Quadro card, this will solely be used to host services I want 100% uptime ie Matrix & home assistant since I break my main server constantly tinkering with stuff
That makes more sense then why your looking at the lower powered options. There are a lot of n100/n150 options on aliexpress and stuff but not messed with any of them myself.
If you have not already https://www.servethehome.com/introducing-project-tinyminimicro-home-lab-revolution/ might suggest some things to look for as well.
