Need help finding this cable.
Take a look at the picture in this link then the link to the front panel I have,I will need to drill holes in the front panel to one that you linked if I want to use it.
If you look at the picture you can see that there are holes that will allow the connector to be mounted with screws that go into where it's mounted to a bracket or it can be mounted with screws that go into the holes that I circled in red where are intended to allow you to mount it to a PCB.
https://www.amazon.ca/GRAUGEAR-Inte...6423&sprefix=usb+c+front+panel,aps,103&sr=8-5
https://www.amazon.ca/GRAUGEAR-Internal-Required-Computer-G-MP01/dp/B09XV6XDLJ/ref=sr_1_5?crid=3PUAEF1MVPJ0M&dib=eyJ2IjoiMSJ9.GQzPKZZ3LqAD0iuQa6Iwqas1Y_ywx6-aZ4hsIOvwGoahZ9dVesfPuGuxMENmjiAiLFBl02Asvu1XxitxW6ujkX7qDNTDrGLb4KujgfRjkuxNTJr_rlQEhUW_k9xl_JYyTstZ055BhJwSWR21LfK5lmKPSboSyniW6boNc6L9R3RmeGlRP2t08oHnBAdG4blNAof6INTW9a0xmI2mXvxoIBtWCM0srXy8o246nwPTFjBxFSmwJY3w5v7swYb4tKErYAJOLO2GoE9VN76Dll-fTrGxmpt_c6TJS6JUmlESiYc.YwuYEa78w0fGJEfpjDAp59EJzamBT07L_9a0zdG7OEw&dib_tag=se&keywords=usb+c+front+panel&qid=1727306423&sprefix=usb+c+front+panel,aps,103&sr=8-5
Willing to bet that is going to be near impossible to find if the manufacturer won't sent the part.
I'm thinking of just drilling the front panel to accept screws the way the connector screws onto a bracket and just use 2 button head screws as I don't really care if I have 2 screws sticking out a bit.
