NOTICE - PC builders, when asking for input on YOUR projects Please Tell
upgrade
I have an asus 939 pin a8n deluxe mobo with 4000+, 1gig ram duel channel, 2 gigabyte 6600 vc sli combo, gaming machine want to upgrade 2 more meg ram,and 2 9800 gigabyte cards these cards are pcie 2.0 x 16 will they work in pcie x 16 slots? have 4 harddrives 2 55 gig ata 100 2 sata 250 audigy 2 sound card plextor 716 optical drive and generic dvd optical 500 w psu. I plan to upgrade the psu to crossfire certified thermaltake 750w and the 2 gig ram upgrade is the same brand and cas latency and timing i believe that part will be fine. My main concern are the video cards. any help would be appeciated.:thumb:
Tom to answer your question, yes they will work, I dont believe any video cards are made to fully utilize PCIe 2.0 speeds yet most dont even fill the bandwidth of PCIe 1.0 so you wouldnt notice any difference one way or another, especially with the 9800s.
hi guys help plz
game, internet, Crimson Editor and media player
1500... cheaper if possible
local... saudi arabia
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
intel for cpu is MUST.
no
no
no
soon as i can...
SSS, better start your own thread in this New Builds section. Also:
Unless you provide local vendor websites, I don't think anyone can help you here since we don't know the pricing over there.
I would like to see either a slight modification or some 'descriptions' added to help guide people posting with this format.
-This question should not only be what you're using, but the performance you want in these tasks. i.e. you want everything to load fast, or apply filters/encoding real fast or you just need it to work, even if it takes a bit longer. Do you want to multi-task and run lots of things at once? What will you usually run at the same time?
-Does this include taxes, shipping, extended warranty coverage, etc. What isn't included in your budget and you have a separate budget for?
-This includes re-using peripherals such as a monitor, keyboard+mouse, speakers, your copy of an OS (i.e. windows retail version).
-If you have, what conclusions have you drawn so far. If you haven't, why not (maybe just intimidating)?
-If you plan to over-clock, what are your expectations and current experience level? What do you want your experience level to be after you finish your over-clock?
-Have you bought any parts yet, when are you starting to buy parts and when do you want to physically be putting it together?
9. What resolution and settings do you use?
-If this is for gaming, tell us what resolution and the settings you wish to have in games (max everything, high, medium, or low). Do you turn AA on and do you care about gaming technology with PhysX, CUDA, eyfinity, 3D, etc?
10. Are there any specific technologies you want?
-Is there something you don't want to go without? USB 3.0 support, wifi n, SSD (solid state drives), blu-ray support, SATA3 6.0Gb/s, Super quiet case (low noise system), all-in-one memory card reader, specific front panel support? Those are just a few examples. If you aren't sure, but know you want to have 'the latest and greatest support' then just say so.
I find that I'm constantly asking for more when people use this 'pre-built' Q&A and they aren't putting much thought into each category and understanding why we ask. If someone would be willing to make some update, I would much appreciate this as it would really help everyone.
I agree, I think this sticky needs to be updated as it is almost 4 years old. Your updates are excellent and gives people a better understanding of each question.
