Rants etc.....
Just my friggin luck.
hehe had a few of those happen nothing like a using an empty can of V8 and a couple of hose clamps works great lasted me a year .
What drivers are you using? I have tried this three times w/ three different drivers. Nothing seems to work.
Was the latest drivers for a GTX 760 on Windows 8.1; 335.23 at the time I think? I had to uninstall using clean sweep before it would work. Although, when I was googling the issue I came across a range of solutions for various people. I saw everything from reinstalling flash, to java issues (that one didn't make sense to me, to uninstalling specific Windows updates. The driver just happened to be the one for me.
Yeah, used one (exact match for the donor car, wooot) in surprisingly good condition was $12 at Pick n Pull. I had $13 credit for PnP, so it was $20 in total for the bolt/spring and gasket from a store here. What a ripoff for those...too bad I kinda need my muffler since I'm quickly going deaf when it hits anything over 2k RPM.
The issue is that it is not simply worth fixing. Its cheaper to just get a used one and do it right.
But all I'd be using is $.50 worth of welding wire. Anyhow, I don't disagree especially when you have such a good place for cheap parts. Ontario sucks for that.
Seriously?????
So "In order to better serve our customers" they've stopped providing the little wallet sized forms that can be easily stored in the vehicle????
It's not like I get pulled over every day, but "just give me a minute officer while I pull this briefcase sized registration form out of my trunk" isn't going to improve his/her humour........
