looking for a video card. want to spend $400 or less plus shipping. just looking for something to play some games here and there @2560x1080.
do you have any preferences? like AMD vs Nvidia, how much RAM it's got, how many monitors it can support? what selection of connectors do you need? what are you going to use it for? what CPU is it going to be paired with?looking for a video card. want to spend 2-300.
Brand does not matter, resolution on my monitor is 2560x1080, i have a ryzen 3600. it would be nice to find something that can do ray tracing for Minecraft.do you have any preferences? like AMD vs Nvidia, how much RAM it's got, how many monitors it can support? what selection of connectors do you need? what are you going to use it for? what CPU is it going to be paired with?
changed my price range, ray tracing is not a must.then youd need a 2060+ currently even a 3050 is $500+ the 4000 series is launching soon it may drop the current prices down enough you might be able to find a 2000 for around that price. if doesnt need ray tracing it opens up alot more possibility's
1080ti min for that resolution. I'm speaking from experience. Hopefully your memory is 3200mhz or more. Is your 3600 the low wattage version or the high one? There's two I believe?
