can I use other manufacturer bios for update? the one I have right now is from Oct 2010. or do I just need to upadte AMD catalyst? thank you in advance.
out of curiosity, why would it need upgrading?
if its reference and you find another reference, should work..![]()
out of more curiosity, what would make you assume you have to change the card's BIOS???
i have the exact same card and have the same temps as you do. i think your worrying to much.
matter of fact i dont think ive ever heard the fan run itself up unless ive done it myself.
which is a huge improvement over my old hd4890
