Who else on this site forum sharpen's their own knives.
wade7575
I have been into Spyderco Benchmade Hinderer and a few other higher end brands of flipper style pocket knives not just because they are fun but nothing beats the edge retention of M390 Magnacut M4 Rex45 HAP40 and ZDP-189 just to name a few good knife steels,I also have some really nice Japanese Chef knives that more then just scary sharp and I have one that get's so sharp my mother who was a cut her whole refuse's to use it.
I used to a sharpen called a TSProf K03 which was a good sharpener but it is so large and you need a lot of different part's for it.
I just picked up a sharpener called a KMFS Vantaedge that doesn't need a bunch of extra crap to just sharpen a knife and I can also sharpen a knife in a bout half the time as well,the Vantaedge also solves a lot of problems that are common with most guided knife sharpening system's.
What the Vantaedge solves is that all guided system's that use clamps always miss part of the edge when going around the curve of a knife that has a big curve or you get an uneven bevel,the reason for that happening is because most guided systems have a mast at the back that is raised and lowered to change the sharpening angle and when the knife goes from the straight section of the blade and around the curve the edge of the knife is getting closer to the sharpener which means the angle is different and because the mast can't move on it's own the angle doesn't change and that's wh the stone gives an uneven bevel or just palin and simply miss's part of the curve in the edge.
The Vantaedge however has the angle locked in at where the mast and guide rods meet and the mast can slide up and down when sharpening which also allows the sharpener to automatically compensate for a perfectly even bevel everytime,plus with the Vnataedge the way it works it also automatically compensates for different stone thickness's as well and on other guided system's you need a digital angle finder and check the angle after each stone change.
That's my Vantedge sharpener with my Spyderco Manix 2 clamped in and waiting to get sharpened.
And look at that perfectly even and razor sharp bevel after zipping threw the steel with my Venev diamond resin sharpening stones.
This is the stock angle selector that has 15 17.5 20 and 22.5 degree's to choose from.
I also got a few upgrade parts such as their Multiangle Head which goes from 10 to 29 degree's and I needed that for knives I sharpen at 10 and 12 degree's.
I also got the Hover Spring up grade because as the stone goes around the curve in the blade the back rod that goes threw the frame of the sharpener dip's down and the spring push's it back up,the rod dip's down it's automatically compensating for the angle change.
If you watch this video at the 4:19 point and watch the back rod you can see it going up and down and thats the sharpener automatically compensating for the angle change.
If you want to go down the knife sharpening ribbit hole just order from these guys and get the sharpener with the multiangle head and hover spring and you'll hooked like I'am if you like sharpening knives so your chefs knife doesn't feel like a butter knife when trying to cut something.
https://www.chicagoknifeworks.com/?s=KMFS&post_type=product&dgwt_wcas=1
Holy crap, that thing is crazy. I have a full set of German knives (Henckels) that I have had since I was a very young man. I sharpen them by hand once or twice a year using a 2-sided wet stone. I have never felt the need of going donw that rabbit hole lol
For me I have a good amount of really nice pocket knives as well and for it's the problem of muscle memory and sharpening them they get a really good sharp edge.
Plus with some of the steels I have and enough Vanadium Carbide in them diamond stones of some sort are pretty much a must and a guided system will always give you an extremely sharp edge.
I had a pocket knife made with a steel called ELMAX and man that one took more then just a scary sharp edge and didn't do to bad at edge retention,15 degree's per side is your most common angle for most pocket knives and 12 is getting lower,I know at 15 degree's and take to a 20K edge and then stropped with diamond paste that was 30 and 50K I didn't even have to touch my skin and all had to do is just plow threw my arm hair every single hair in the of the edge got cut right off and not a single hair the past got missed.
Wow, that's amazing, that kind of edge on a blade really does make a big difference, eh.
For me, pretty much all the blades get the same edge or pretty close to the same. I learned by trial and error, which took me a couple of years, but now I can sharpen them all in about 2 hours, and they are more than sharp enough for my family, so all good.
If I hadn't gotten the knives from my stepfather, who passed away many moons ago, I doubt I would have bought them since they were not cheap. Plus, with me only being able to use them for making my wife food, they don't have any real use for me, with the zero food in my diet lmao.
But very cool, I never thought much about or understood the levels you can go when sharpening your own knives, thanks
I use the kit highlighted in project farm. Lansky sharpener is effective and came with a variety of grits
I had a Lansky many years ago and I didn't hate the idea of it I hated at how crappy the clamp was I could get any knife to hold in the clamp,I think they improved that in some way now from the very first one.
I don't like buying things because they cost a lot and even something like this sharpener I checked out where the cheapest place was to buyand right from KMFS they have to charge a 21% Vat tax as well which really sucks,there was the place in Chicago and a place in Finland to buy from and they had free shipping and is was 4 day UPS as well so that saved me 65 bucks over the other place.
I know with kitchen knives and with some people you can never get it threw their that if you spend around 150 to 300 on one knife and you get to know your blade steels first they will not only take a sharper edge but hold way longer then a Kitchenaide knife or whatever the cheapo brands are,I also got a really good paring knife from crappy tire and it's made by Paderno and it holds it's edge for 8 months to a year and never really dulls until the end and it just seems to dull all at once,I figure if you have to sharpen the knife and take the time to do it get a knife that will at hold the edge so it's enjoyable when you go to use it.
I forgot that you don't eat food and what your condition is and you told me before and I forget what it is but I remember now in a PM you told me about it,I'm also a bigtime foodie and enjoy great tasting food and I'd rather someone take a peace of cast iron pipe and cave my head in when I would least expect it then to not be able to enjoy food.
I have a guy I met on facebook in Ontario that does laser engraving and he has engraved some metal tags for me and also a some NVMe ssd nclosures so I can know which is which because I always have a few on the good and he told me there's certain things he can't eat and his diet is very very restricted and he stuggles a bit with wanting to eat stuff that he shouldn't and he doesn't because he said the hell he pays for doing so is unreal and choose's to just not give in.
This is an interesting thread! I have more knives these days, everyday carry and such, and I definitely need to get better at sharpening them. Buying new ones when the older ones get dull is pricey!
Just kidding, just kidding... :)
