- Location
- Moncton NB
At this point they are waiting on manufacturer and not sure if full replacement or if they will be able to just swap out the control board. I men it should be doable, but you never know.
And back to the other rant of the switch and outlet.
Just taking a quick look before I have to head out briefly but this is what it looks like in the switch.
Now from the quick look am I right in thinking the easy way would be to just completely bypass the switch? Just take the hots off switch and connect them and put a blank plate on. Of course then I am stuck with a sensor light but I mean that isn't that bad of an option either.
Thoughts?
Looks like it's a straight up single pole switch. If it were me I'd take the chance and just tie them together if you absolutely have to use that outlet for your freezer.
I'm assuming the light is a ceiling light? Maybe one of the wireless remote switches like this one?
