Might have to get your dough recipe from you, I generally do the Kenji Lopez pan pizza method, which is fantastic, but more 'focaccia'-esque, you've got a smaller but more consistent air pocket size throughout from the look of that photo.I've made probably about 45 pizzas now this year. Up until a couple days ago I've never made 1 the same. Always changing technique slightly. Trying to perfect the outcome. But I've think I've finally reached the point where I can't figure out anyway to improve on technique for a pan pizza.
The dough isn't needed. Water,50/50 wheat / white flour, salt, a bit of ground dried garlic, and yeast. 75% hydration. But I use 2 tablespoons of fat in the pan for a crispy bottom. Currently using bacon grease but will switch to ghee after I'm out.
I par cook the crust. 350 top burner / 500 bottom. 10 minutes. Can put toppings on immediately. Or set aside for later. Found no difference really.
Then 10 minutes at 450 / 500 with toppings. I've found its even better after reheating.
Looks fantastic!
