any suggestions for a relatively decent, budget gas chainsaw?
Honestly depending on what your doing either something used or something battery powered and skip the new gas ones. It is often just another engine that needs to be maintained when unless your cutting down fully mature trees a battery one will do the job.any suggestions for a relatively decent, budget gas chainsaw?
I need gas...and probably 4-stroke (I know this likely precludes 'budget' as an option) as I HATE the smoke 2-stroke engines pump into your face. probably something in the 60 - 70cc range that can run a long bar.Honestly depending on what your doing either something used or something battery powered and skip the new gas ones. It is often just another engine that needs to be maintained when unless your cutting down fully mature trees a battery one will do the job.
Mostly just spending time organizing and getting shop ready. Organizing is like my to go 'hobby' these days@lowfat you've amassed a huge quantity of tools over the years, I'd like to see pictures of something you've built someday.
Just get electric if you don't like smoke. Most good gas chainsaws are two stroke.I need gas...and probably 4-stroke (I know this likely precludes 'budget' as an option) as I HATE the smoke 2-stroke engines pump into your face. probably something in the 60 - 70cc range that can run a long bar.
lumber. custom milling.Just get electric if you don't like smoke. Most good gas chainsaws are two stroke.
If you aren't doing big work, electric works great.
Gas is for cutting up big logs and lots of them.
I have 2 gas and one electric pole saw and when sharp either cuts a branch just as fast.
Well then you are stuck with two stroke. Husky or Stihl. Can't go wrong with either brand. My big saw is a jonsered which is just a husky with red plastic. I used it for 10 hr days bucking in the bush for years without issue.lumber. custom milling.
