NVIDIA GTX 780 Ti Review Comment Thread
A friend of mine bought a NV card a week or so ago and got the 3 codes from there NE store.
Not sure what's in play now, but if I was to buy a card from them I would want the games to use or sell.:thumb:
I'll bump my 3930k back up to 5 Ghz and Post some Benchmark comparisons of Tri SLi 680 Classy's OC'd vs SLi 780Ti OC'd........should be fun ;)
Willl run the standard:
MK11, MK13, Heaven, Valley......
Thanks, will be waiting, can you also check BF4? I'm trying to decide on a third 680-4GB or going sli 780ti like you, thermals aren't a problem as I'm using an R4E in a HAF-X.
No interest in seeing what mantel does with BF4?
Sorry guys I've lost all interest in the Battlefield Series...BF3 was the last of those I'll be playing.
^^^ That is absolutely correct....bear in mind there is a lot of "false info" re: the requirement for more than 3GB VRAM if you're only using a single 1440 / 1600p monitor. imho 3GB of VRAM is more than enough for single monitor....just 7 months ago I was running SLi 580 Classy's with 3GB VRAM with no issues.....perhaps B4 (which I dont play) reuire more for 1440p....? no idea, but I dont tink its a big issue unless you're planning Surround or 4K.
