Eldonko
I would go with P5Q-E or Biostar I45 for overclocking ability. Otherwise looks good.
Mushkin is pushed here because MushkinGreg goes above and beyond with support on the NCIX forums.
Also, what resolution will you be playing at? If it's not that high I would suggest a 4850 over a 4870. The framerate differences at 1680x1050 and lower aren't worth the extra $100. Plus if you're getting a P45 motherboard you can always get a 2nd 4850 in awhile if you find 1 not fast enough.
Other than that you list looks pretty, you did your research well. One thing I would suggest to you, buy from ncix.com, 2 advantages, service is just outstanding, second you can pricematch and still save yourself a few bucks more.
Asus P5Q - $121.90
[FONT=Verdana, Arial, Helvetica, sans-serif]Corsair TX650W - $79.99[/FONT]
Mushkin EM2-6400 2 x 2GB - $69.99
Seagate Barracuda 7200.11 3.5IN 640GB - $79.88
Intel E8400 - $169.99
Diamond HD4870 - $268.32
Cooler Master 690 - $72.60
$862.97..
Now as you can see your already saving, since the price is with the case added up, your price was without it. NCIX is a great place to shop, you should also check out our HWC Sale for the members, you could also find a good deal there too http://www.hardwarecanucks.com/foru...are-canucks-forum-sale-aug-25th-sept-8th.html we have these every few weeks, next one probably starts 2 weeks from now or 3 weeks, you know prices on the internet change every hour or so, if you wait you might not get some of those good prices on some parts, but you could get one hell of a deal on something that could even save you more.
Good Luck on your build.
he was very happy with the cable routing and general finish.
just curious... what about cpu and heatsink? or other that you cant see...
