SSD added to Dads old beast and WIN10 installed, it is not very good, worse actually. It all seems faster on startup, well I guess it really is, but once you go to do anything it all goes wonky. Cannot open a webpage, well the browser opens but cannot open a webpage other than the startup page. Click anything and browser locks up, cannot even get Chrome downloaded.
Turn off Fast Startup. That's what's causing those issues. Seriously, I don't know why Microsoft keeps putting that stupid setting on by default. It causes nothing but issues. Sure it saves you maybe 2 seconds on startup, but causes nonstop headaches for everything else, unresponsive apps etc. Especially on older computers.
Here's how to turn it off.
Open windows explorer. Click in the address bar and clear everything. Then type "Control Panel". On the top right change it from "Category View" to "Small Icons View". Select "Power Options". On the left hand side click "Choose what the power button does". Near the top of the screen click "Change settings that are currently unavailable". Then take the tick out of the box for "Turn on Fast Startup". Click save and reboot your computer.
That should fix those issues. Just remember that anytime Microsoft does a "feature" update, ie when they update to a whole new build of windows, you'll have to remember to turn that setting back off again. Regular updates are fine, but you'll have to remember to check after feature updates. For some reason Microsoft keeps turning it back on even though it cause people no end of issues. Seriously, you'd be surprised just how many issues that one setting is responsible for. It's insane.
So sorry I didn't respond to this issue earlier. I've been really busy the last several weeks. Otherwise, I would've told you how to fix that issue a lot sooner.
Also, be careful with the latest version of windows, because it's having a lot startup stability issues right now. Killing Fast Startup still helps in most situations, but right now I'm still experience random occasional startup issues. Except now, a simple restart doesn't always fix it in my case either. I'm having to resort to fully shutting down the system and then starting back up before they'll resolve themselves now. These issues didn't start until I installed the latest updates. Microsoft really needs to get their act together, because they've been releasing a lot of really half baked updates over the last year and a half. They need to give up on feature updates for this year and spend a year focusing on stability and reliability updates, because right now, windows is a real mess of an OS.
