DDR5 …Eyes n Ears Open Please.
This is interest To say the least…
Yes bingo! That makes sense to me now.
But could you also mount on the front rad? You have lot of space there it looks like and then none of the motherboard or RAM would be covered at all.
And I might have said it already but golly that is a cool looking motherboard! (y)
I wish, the video card is 310mm which makes the pump just not fit due to the rad up front.
It’s close, but just not enough space.
Fun fact, I have a 1000w PSU and this setup uses all the pcie cables.
2 8 pin and a 6 pin on the MB plus 3 8 pin for the vid card… that’s a lot of juice
That GSkill 5600 C36 kit is the same kit I was able to order from the Egg...should be at my house Friday 24th.
I received notification today from Corsair that the Dominator 5600 / C36 kit shipped from them today via Fedex....
Never would have thought I'd have 2 kits enroute....stoked I lucked out getting that Dominator kit ;)
I know what I ll be "mucking about with" in January ;)
I read thru some of the OC'ing guides....head started to hurt....looks like I have to try n figure out "By Core OC'ing" vs the old "brute force' method....
Us Zen users have been dealing with this for a couple years...
Sounds like you're falling behind the times. Getting a bit slow in your old age, perhaps? ;)
Seems like the same specs on the 2 kits, so probably the same memory. You planning to keep the gskill, or the dominator?
The GSkill kit is Samsung and the Dominator kit I believe is Micron....likely keep the Doms but will probably try both...I like the looks of the Doms w a little RGB.....
I see on Tracking my Corsair kit is Anchorage AK Fedex sort facility...coming from Taiwan maybe or China....not sure where there made.
