the 'let's talk about unusual stuff thread.'
Izerous
Folding Team
Edmonton
I'm trying to think of appropriate use cases for a flame thrower dog outside of combat and all I can come up with is controlled burns. Makes me wonder if this isn't something that some fire departments that have to deal with regular wildfires & controlled burning might actually end up utilizing.
LaughingCrow
Southern Ontario
Agreed, it could have it's uses when limited to trained personnel in forestry & fire departments. But see it being used improperly and foolishly too easily.
Marzipan
Prince Rupert, British Columbia, Canuckistan
in the US it obviously is being marketed as a property defense system.
FreeKnight
Edmonton, AB
I've worked with some of the controlled burn crews on oil and gas projects. I'm not sure this would really work. Any of the areas that aren't off a road and have a controlled burn started are typically rough and irregular terrain, either woody or fields and these robots don't do all that well on such challenging terrain. On areas attached to road I'm not sure you wouldn't be spending less by just having a crew with a pickup and some tiger torches.
In Canada it'd probably be less likely as the burn crew companies are generally indigenous owned and a kind of 'pork barrel' projects to appease local bands, and I doubt they'd let the work go to robots without a fight.
Yep, with all the damage from burns started by stupid shit like gender reveals in the US, I could see this causing major damage from 1-2 incidents of stupid people with money to burn.
Izerous
Folding Team
Edmonton
I was less thinking planned controlled burns and thinking more the ones they execute at times with wildfires to try and burn out areas to burn out fuel before the forest fire reaches some areas. Not a perfect example of course but thats where my thoughts were going.
Kind of like last summer when people were showing up with bulldozers trying to make fire breaks as the fire is encroching on Drayton Valley and other communities nearby and having a "person" near the fire is dangerous but a robot bulldozer would have been able to go closer and not endanger anyone.
LaughingCrow
Southern Ontario
The last 3.5 floppy was made by SONY in 2011 but they're still in wide use...
But it is well-known that some Boeing 747s, for example, use floppy disks to load critical software updates into their navigation and avionics computers. While these older aircraft might not be so common in Europe or the US these days, you might find one in the developing world, for instance, Persky hints. There are also pieces of factory equipment, government systems – or even animatronic figures – that still rely on floppy disks.
https://www.bbc.com/future/article/...ith-this-obsolete-computer-storage-technology
Marzipan
many a million dollar cnc machines rely on floppies.
