It is interesting to see the difference in reviews.
I think it was in Jay's video, he mentioned their AMD setups are using EXPO RAM at DDR5-6000. Whereas the Intel setup was running on DDR5-5000. That would be a bit of a cost difference too perhaps if AMD needs 6000MHz to run at full speed and Intel only needs 5000MHz. I still hate video reviews as it not easy to compare these finer details as readily as text...Can you expand on that point a bit more? I did a spot check on Gigabyte Z690 Elite AX (DDR4 vs DDR5 is about $10) vs X670 and the price diff is about $50. So I guess you could get the DDR4 version and re-use existing RAM to save money. Looking at i5-13600KF, it's the same price as R5-7600X so technically the 7600X is better value since it does have an iGPU compare to the KF.
This is REALLY disingenuous of a comparison. Especially coming from GN.Took a snip of the i5-13600K review from GN:
So my problem with this comparison is that GN didn't include the 13600K with a DDR5 board and memory. They also didn't do a comparison between B660 with DDR4 vs DDR5 to show what kind of performance there is between DDR4 3200 and DDR5 5600.
Absolutely! They say that in the 13900K HardwareUnboxed video I linked. Even though AM4 is on its last gen, that is an awesome CPU to base a system around for the price. And dropping it into an AM4 system you already have... Priceless!
