So the Assassin III doesn't use a backplate with am4? I thought that was the problem. There is an am4 kit with this cooler but there is no backplate so I thought it was just missing. You're saying it doesn't need one?
Definelty check factory sites for compatibility. That said, the main point is that the back plate on AM5 is not removable (shouldn’t be). So generally any coolers that used the stock AM4 backplate should be compatible on AM5 using its backplate. If the cooler came with a custom backplate, it will be a no go…unless the company makes some kind of aftermarket AM5 adapter.So the Assassin III doesn't use a backplate with am4? I thought that was the problem. There is an am4 kit with this cooler but there is no backplate so I thought it was just missing. You're saying it doesn't need one?
I really like the mesh on the bottom of the side panel. I run my GPU for long hours doing machine learning stuff and would like the extra airflow in that area.Lian li=boss cases
The compact version? I think the normal should be about $70+ more than the Lancool.Fractal Torrent looks interesting too. Same price as the Lancool III right now.
