Battlefield 3
Ok, did some benchmarks with fraps, will post my results and specs.
AMD Phenom II x4 940 @ 3Ghz
4GB G.Skill DDR2 RAM
M2N-E Motherboard
EVGA GTX 560Ti SC @ 942/1884/2106 running the beta 285.38 drivers @ 1680x1050
Settings are as following: (screenshot)
I was averaging 55-60FPS on those settings in operation metro.
Awesome, thanks. What do you guys think so far? How're your systems running? I had to knock my resolution down a bit to keep it playable. Changing the settings from high to medium didn't do much. Running 4800ish x 900 with 2 5870s on high gives me about 50-70fps.
As Supa and I were disscussing in irc it would help the ppl posting "can i run bf3", threads if we compiled a list of what fps ppl are getting with there hardware and res.
So thanks and keep them coming!
I'll post up some 6970 single and xfire under a 2600k@5.
What CPU JMCD? and how much is it utilizing.
I got my beta key but I get the "an error has occured with your setup please reinstall"
Downloaded it twice from origin and still nothing not sure if it's my rig or the game
I'm running
Q6600
4gb ram
Gtx260 (216)
Vista
It's weak but should run BF3
man oh man is it ever buggy.. like when you're prone you can see straight through the ground, helped me with a few kills but still.
it lags like hell, not because my computer can't handle it, but because it's so buggy. non the less i enjoy it more then the alpha.
I've been getting terrible mouse and movement issues. It seems like mouse input isn't being translated properly into character movement for some reason. Lots of things for the developers to work on for the next few weeks before launch.
i7 920 @ 4.2ghz. I'll have to check the utilization, but my guess is damn near 100% as my temps are toasty!
