Case Pics
Thanks dudes! Major compliment but I must agree with Botat there are a few tweaks which would need to be done to be up to his standards. Don't offend him. :P :ph34r:
It's a major compliment to me though as he was my first source of inspiration. :D <3
Still think this is one awesome build you did there, but one thing that would look good is go get some matte yellow and a finishing sponge and just use a small amount on the sponge and lightly push it on the top of your ram, it will give it a more msi Bigbang look without breaking the bank and easy to wash off if it doesnt look right.
My 2 Cents
it's a very nice build it give me idea for my Z77 power, but it will be on air this one, probably just yellow fans.
My 2 Cents
Ya know I originally planned to do this but I feel like it might just end up looking overkill. I am kind of scared because I can't undo it if it looks bad.
Also once my Dwood products arrive I might order a custom motherboard tray with perfectly spaced cable routing holes. Also considering a custom reservoir faceplate.
Just finished cleaning mine up and upgrading the 3/8 hose to 1/2 inside diameter.
CPU OC to 3.9Ghz
GPU to: Clock 702, Memory 999, Shader 1728
CPU Idle 31C - Load 44C
GPU Idle 33C - Load 40C
Any specific reason you have your reservoir mounted upside down?
Looks good otherwise.
Last pic before the upgrade and hopefully to a new case too
