3.0charlie
I may take my board out to replace the server case for a 4U size. If I do I'll send you the layout.
This is all I can find so far:
SWTX (Server Workstation Technology eXtended) (SuperMicro) = 13" x 16.48" (330mm x 418mm)
and:
SSI MEB SSI MEB is known as a proprietary Serverworks SWTX form-factor (16.4" x 13") and Tyan SSI/Extended ATX form-factor(16.2" x 13") , this form-factor is for Quad-CPU solutions. Howver the standard is (16"x 13") . Special cases are required for these boards. Dimensions
- 16"x 13"
- 406.4mm x 330mm
Blue = shared with ATXI'm looking more for the screw placements if at all possible.
No I don't, sorry. Ask Supermicro online support - they should be able to tell you. SWTX is a proprietary form factor.
funky:
