Let's go Team !!
So you guys w/ the 48-core rigs, what kind of heat do these babies put out? You think that a single 3x120mm radiator will be able to maintain decent temps w/ three medium speed fans? I am ripping apart my stacker to get it to fit an SWTX board right not. Just not sure what I should do for radiator holes.
I'll chime in for the lonely 32-core rig owner.... :biggrin: 460-475w from the wall, with 5 fans and a single ssd.
One more question, how does the MEB factor form differ from SWTX?
I believe the difference between the 2 are: SWTX is proprietary to SM, the board is a tad wider and that same mid stand-off location is different - only looking at pictures, unfortunately.
My Tyan is SSI-MEB, and the SM owners should confirm this using the drawing I did.
For the rest of us out there on team 54196 who does not have a 23 CPU rig, keep the points coming! I got my two lonely rigs folding as hard as they can.
2.5 million ppd today!! Keep em coming everybody! The weather is warm, so the points are appreciated!!!
Those of you with the 23 cpu rigs...keep it coming too ;p
Heh... I'm still folding 24/7, but I'm going to take pity on my young lad this summer and turn off the heat pumps for the summer. (No A/C, little airflow, 3X OC'd CPUs, 5X OC'd GPUs @ 24/7 = a hell of a lot of heat being pumped into the basement where his man cave is.......... ;) ).
Yeah, I'm going to be taking my home boxes offline from folding very soon.. today was the first day we have the air conditioners going.
We're getting a new heatpump / ac unit at work on the 30th, so i'll hopefully be taking two of my SR-2s there. Dunno if my third will be folding, or just playing with virtualization at home.
My main workstation is doing the -oneunit thing now.. possibly doing that with the dual 5639 SR-2 box too.
Ok, i can't seem to find the post outlining how to set up V7 to do big adv WU, as i dont have the time to set up parallels this evening for the linux image
Thanks, i tested out funneling from the ac to the intake rad fan, though i took it apart once i felt condensation on the metal. Going to exchange it with the plasticlike material homedepot had for 2$ more to help avoid that.
Temps were great though, wish i could remember load but stock speeds idle it was 20C and 4.0Ghz 1.4Vcore it was 25C
As of the last update, we have a new Points Leader. But...
there may be some shuffling between the #1 and #2 spots!
