None of the one's I've used has. They've all been slide in and out, usually with only a portion of the card going in so it's easy enough to pull out. I'd probably avoid a pop-out spring if you're worried about longevity, just one more thing to break.I don't suppose any of these have a spring loaded latch for the SD slot like a laptop has?
