mines freezing on the menu where u pick difficulty and i have to close via task manager
For me it gets to the loading map screen but the "Press any key" message never comes up. I have to ctrl/alt/del to task manager, for me it seams to be a memory hole because if I leave it long enough x-ray eats all of my free memory. Via Task manager.What does the bottom part of crashlog say? It's here: Steam\steamapps\common\stalker call of pripyat\_appdata_\logs\xray_yourname.log
He he, I already tried dropping everything to the lowest settings @ 1680 x 1050:thumb:Ok, now lower the texture slider somewhere between 80-50% and see what happens.
Reverting to 10.6 worked for me this morning.some of the tweaks I think might do the job:
- move the texture quality slider to 80% or less (best solution)
- disable Crossfire
- use DX9 settings
- use the last known to be working Catalyst 10.7 drivers (only works on 5xxx series and below)
Ha ha you are 100% correct 10.7 not 10.6.so it's 10.6, not 10.7?
