No Wires???????????????
Vinnie
Barrie
No Wires??????******UPDATE******
Just came across this website by accident. None the less was all excited that it was a Canadian. For my first post decided to post some pics of my computer that I put together a year ago.
Here it goes:
Specs:
AMD Athlon 64 X2 4600 2.4Ghz, OC to 2.6Ghz
Motherboard: Asus Crosshair
Cooling: 4-120mm, 2-80mm fans, CPU-Blue Orb 2
Memory: OCZ 2GB DDR2 800Mhz
Video Card: Ati 1900XTX, OC to 688/792
Harddisk: Western digital 150Gb 10,000rpm
CD/DVD Drive: ho knows (it works)
CRT/LCD Model: 19" Samsung SyncMaster 940bf
Case: Thermaltake Armor
Sound Card: Original Audigy
PSU: Thermaltake TWV 500W
Software: Windows XP
Mods:
2-120mm fans were added to the front blowing air in the case.
On the back of the case a 120mm, and 80mm hole were cut, so the 2 back fans can take the hot air out of the case more easily.
Material used to go in front of the fan so I don't chop up my fingers is basic plastic gutter guard bought at home depot for $3.
ATI 1900XTX mods:
OC to 688/792
Temp before mods at same OC were:
Idle: 52C with fan @ 40%
load: 72C with fan at 100%
Voltage regulator:
Idle: 49C
Load: 67C
After the mods as in the pics, same OC:
Idle: 44C with fan @ 40%
load: 66C with fan at 100%
Voltage regulator:
Idle: 44C
Load: 60C
For something that didn't cost anything, it worked very well, I was very impressed by the results.
welcome
Welcome to the forums. I'm in USA though but i love this place more than most USA forums lol the people are smarter or something:whistle: lol
oh btw there is a thread for just case pics too. and.. oh lo0l just noticed that this is in the gallery sorry lol.
Great Cable management!:thumb:
Now show us pictures from behind the motherboard tray, then we may be able to find some wires.:bleh:
I cant wait to get rid of my antec 900 and move into something from lian-li or silverstone, but Christmas shopping comes first...
Anyone else notice he doesn't have a hard drive in that system?
And its super easy to cable manage like that with the proper case.
Nice!
But without wires that case looks really empty, get some watercooling in there now! :thumb:
Great works!
It is painfully obvious the HD is in the 5 1/4 bays. Also, it is no where near super easy to wire a case like that with ANY case. If it is sooooooo easy for you to do it then post some pictures of your case, since it must be perfectly wired, for us to critique.
I said with the proper case and unfortunately mine is not one of those. The Aurora 570 has to much open space and not enough pockets and space.
But my case does need to be redone so when it is I will take pictures.
