G
Guest
Guest
Yup no point IMO, for price point might as well grab the x versions over the xt.
That CPU is insane. Need to wait for the 3900XT review from him to see if it OCs the same.Well, GN had better luck with their 3600xt. Actually it was a beast of silicon, but even they dont recommend it at the price point unless you're an active overclocker.
so...it seems the XT's are being built on a revised 7nm tech that will also come with a faster Infiniti Fabric if the details on Renoir are correct.
I said revised...matured, as you say, would have been the better choice of words to use.where did you read it is a revised 7nm? From what Iread it was just saying that 7nm has become a more “matured” process...this would be the case for all CPUs now coming off the production line, vice something new.
