Lysrin
Contraband at the stage I am in the game is worth far less than the Magpulse and other weapons and Suits I am picking up that sell for 5000+ Credits, so its not worth the hassle of going to the Den when I can just go elsewhere and sell the weapons from the ships I raid.
Early game, yes, just not where I am now.
Ship builder is where you want to go, just look and see what Shields are available to you as Class A and replace accordingly. The Upgrade system is a bit buggy and I don't really trust it.
Once you get a feel for actually using their ship builder, using the upgrade system is pointless. Also because it won't upgrade something in situ that does not mount the same as the prior one.
I.e. there could be a better engine than you currently have, but it mounts from the front and not the sides so it won't bring up the option for you because you have to change the location of where they go. This is where the Ship builder is key. Could be the same with the shields. Some are Top Mount, others are side mount.
Maybe I'll go onto Twitch once I get some more credits in the bank.
I just cleared my account again doing a major overhaul of two ships. I had rebuild one but I didn't like the end result in how it handled itself in space so I went back to Stroud to make some modifications. I like how I have the engine design and performance now vs what it was when it was originally rebuilt.
My next goal is to make some smaller fighters. I always push 40M with my ships. I need to start building smaller.
Got it. Thanks @Soultribunal ! That note about an upgrade vs. builder and how components fit is likely exactly the issue I'm having with the Razorleaf. I'll investigate that.
Searching, using info from yours and others comments, I also found this article. So Bethesda does provide some official guidance into this activity:
Bethesda Support
Interesting note (bold me):
"Select the option to view or modify your ship, then choose the ship you would like to modify, and press X on controller (B on keyboard) to get to the Ship Builder. From here you can either delete or move things piece by piece, or you can delete everything at one time to start from scratch."
So the bolded option would allow you to build a completely new ship, you just have to have a ship to select and delete everything from. Weird, but at least there is a way you can do a completely from scratch build. I thought you couldn't.
