Didn't really do a summary on this build.....
- 4X 10TB Ironwolf Pro
1X 8TB WD EZAZ
- 1X 20TB Ironwolf Pro
- 1X 22TB Ironwolf Pro (Parity)
- 2X 1TB WD SN850 NVMe (Mirrored Cache)
- 2X TR HR-09 NVMe tower coolers
- Topton 1X10G, 2Xi226-V, Intel i3 N305, 6XSata 3.0 Motherboard
- 32GB Crucial DDR5 4800
- Seasonic Focus GX-550
- Fractal Node 304 case
- 1X Noctua NF-A14 FLX, 2X Noctua NF-A9 FLX
- Cheesy 6 drive sata cable bundle.
- 10.1" QHD IPS monitor
- Logitech K400 KB/touchpad
- Cyberpower EC850LCD 850VA/510W UPS (1hr+ backup for a clean shutdown in case of power failure)
Total available storage ended up at
48TB 60TB. Currently sitting at less than 12TB with a significant amount of content padding so <25%. I managed to grab 4X used 10TB drives + a couple of 8TB drives for a decent price (one of the 8TB drives replaced a storage SN850X in my main rig freeing up the NVMe for use as the mirror drive). Paid the big bucks for a new 22TB drive that I'm using for Parity.
I'm not completely sure how much value there is to the mirrored NVMe cache drives in this configuration. The system still resides on a USB stick for booting so you're looking at the main benefit being having the docker image files + related app data being served off of the cache. In my current config, new downloads go to the cache drives and are then moved over to the mechanical drives overnight once the DL(s) is/are complete. Files are served from the mechanical drive rather than from the cache so there's no speed benefit to the cache when accessing library content.
The motherboard worked out well. Seems to have more than enough power even when being slammed with a ton of peers on the client. Normal power use seems to be somewhere between 50 - 60W with peaks as high as 73W in worst case load scenarios (cpu use 75% paired with lots of HDD access). That power profile gives me close to 1hr battery backup for a clean shutdown in case of power failure. Memory was overkill as I've never seen it hit over 25%, but that leaves me with a lot of overhead if I decide to add more docker containers.
Case was functional, but a bit difficult to work in. The internal power supply cable was less than ideal for the PSU I used (facing the wrong way). The replacement Noctua fans do seem to be a bit quieter at the medium fan speed setting, but I'm not sure they were necessary. The NVMe tower coolers did a fine job of bringing temps down to 35(ish) on those drives, and the mechanical drives seem to fluctuate between 32C and 36C.
Software side, I went with Unraid Unleashed (total 8 drives including the two cache ones) which gives me a 1 year OS upgrade window with the option to either pay an annual subscription when/if it comes time to upgrade after the initial year expires and/or bite the bullet and buy the lifetime upgrade. I initially started with the most recent version (7.XX) but decided to nuke that array before starting to populate it and went back to 6.xx as a lot of the guides used tools which weren't ported over to 7.xx. Once I got everything up and running under 6.xxx I had no problems upgrading to the newest version. Unraid was/is very noob friendly with easy docker container implementation. Only issue I ran into was the fast transfer option (reconstruct write) not being enabled by default which cuts throughput by close to half.
I won't go into all of the installed software, but I ended up with Deluge client (through PIA) along with Jellyfin to access content. Jellyfin seems to be doing everything I need, although we do find the "next up" feature needs a bit of work. I've also taken advantage of the basic (free) tailscale package which allows for 3 users to have remote access to the jellyfin server.
