- Location
- Moncton NB
I get a little over 2hrs on a 1500/900W model.
Why? I was going to get one for my tv and stereo.UPS are very simple. for the average* gamer, they would want go get the CyberPower CP1500PFCLCD: https://www.cyberpowersystems.com/product/ups/pfc-sinewave/cp1500pfclcd/
but the rule of thumb, no matter what UPS you purchase, the minimum requirement is to make sure it's supported wattage matches or exceeds the wattage of your PSU and all other devices you intend to connect to it.
also, you never connect printers, speakers, amplifiers, etc. to a UPS; well, the surge protect outlets are fine, but not the battery backup.
*average being defined by those that have a gaming PC with a PSU that does not exceed 900w, as there are very few 1500VA UPS that support more. there are a few, which are 2 or 3x the price of the recommended above, that peak at 1050w.
source - me, a guy that's been selling them for 17 years.
How long does the router/modem stay up?
the TV should be fine, but stereos inrush and sustained current will overload most UPS and cause them to fault. of course, there will be some exceptions. that said, UPS are not for running a device when power goes out, they're for stopping them from sudden power loss so you can shut down and turn them off safely. now, if you have a 2000VA or higher UPS, you have more options, but for them you need at minimum, a 20A circuit. and those UPS, get spensif very fast! I just sold two 3000VA 120v / 30A UPS for a communication stack on Wednesday and that ran them close to $7K.Why? I was going to get one for my tv and stereo.
@sswilson I didn't say they can't be used to run something for sustained periods. just that they are not designed for that.
there are circumstances where installing a generator as failover isn't feasible, but every time I've had a project where this was how the UPS' would be used, our reps stress that's operating them out of spec.
