Fudd Rucker
Im planning on overhauling my watercooling system and was wondering if it would be a bad idea to run directly from the cpu to the gpu then out to the radiators? Or would the water be too hot from the cpu therefore negating the purpose of watercooling the gpu?
Im planning on using 4 x yate loon + 2 x sflex 1600rpm fans with a TFC Xchanger 240 and an MCR220 in a giant pushpull fan sandwich. The CPU block is an EK supreme LT and the VGA block will be an EK 5870 full coverage block. The line is running 1/2" tubing and using an MCP655. I would like to cram the whole unit into a custom box later on with everything inside the external custom box and just lines running in and out.
