Marzipan
good to hear no issues with Fido, being I'm with them too.I'll add my 2 cents (CDN). I received the phone on Friday. The phone had around 45% charge so I hooked it up and charged it a bit while I prepped to change over. I did a full backup on my old phone, to the Google Cloud, and then shut the old phone down. I removed my SIM card and realized that I have a microSIM and needed a nanoSIM. No problem, I found a site with a template and just cut it down myself. I thought the worst that would happen is that I would have to go in if I screwed it up, but no, it worked. After about an hour on a standard USB 3.0 port on the computer it had charged about 10%. I put in a fresh 64GB SD card and the SIM and flashed it up. The process to recover the backup was smooth, and it took a little while to install the apps but I was up and running. During setup it asked me what to do with the SD card, so I had it just add to the internal pool instead of use it as a separate "drive". I don't plan on moving it out so I thought that was a nice touch.
The phone sits comfortable in my hand. The display looks pretty darn good, to me. It seems responsive and runs pretty well. I was a little disappointed with the fact it only has 802.11n, not ac. The Speedtest was fine, for an n device though. The bluetooth had no trouble connecting to my Fitbit, about the only bluetooth device I use, so that was good. The fingerprint sensor is on the back and works great. Also, I didn't see any NFC, so if you want to use a digital wallet, don't get this phone. Not an issue for me though.
I am not a big picture taker with the phone, but the couple of test shots look fine to me. The wide angle is impressive, and the bokeh mode is nice, if you like that sort of thing. I have no idea how good the front facing camera is as I haven't used it yet, and might never since I don't do selfie stuff.
Overall impression, for $131 bucks, it is just fine. I'm not a game player with the phone, it is more of a text device and fall back emergency/travel thing, so I expect it will be fine for a few years.
Edit add: Forgot to add, I am on Fido, no problem recognizing the network. I should try voice sometime and will get back and edit again after I try a call or two.
can you try testing a game, just for the gits n shiggles of it?
also, I find it funny how we get upset that we've not got the latest WiFi standard...when the bandwidth N has is still pretty darned fast...more than any Gb wired connection would give you, which is really where you need it, usually. LoL!
