- Location
- Moncton NB
A pair of 140mm USB fans. My new switch runs stupidly hot (69c idle) and the built-in fan profile doesn't trigger until somewhere around 75c if you don't have an SFP adapter installed.
can't you get dummy modules?A pair of 140mm USB fans. My new switch runs stupidly hot (69c idle) and the built-in fan profile doesn't trigger until somewhere around 75c if you don't have an SFP adapter installed.
this will let you essentially create a stack that can be managed as a single device?Finally broke down and grabbed the aggregation switch on my way home. Cheaper at MexEx (after price match) than any ebay or other listings. And used switches with more than 4x SFP+ ports have huge power draws in comparison. 7W idle vs 70W idle kind of differences for older hardware.
8x10G connections. The aggregation means I can link ports together and do things like 6x10G+1x20G, 2x20G + 1x40G etcthis will let you essentially create a stack that can be managed as a single device?
