- Location
- Moncton NB
Heh.... been a while....
Just a general rant about those times when printing just seems to stop adhering to the print surface overnight.... it usually occurs right after changing to a new filament so the first instinct is to blame the filament and try to adjust settings to make it work (or start printing rafts if its a relatively small part that you just need one of), but when nothing works you end up swapping both nozzle and print surface (not necessarily a new surface either, just a different one) et, voila!!!!! Printing resumes as if there was never anything wrong!!!!
Second rant.... folks who create designs that don't sit flat on the print surface.... I never think to check the bottom of my cura slice, but often when you look at the bottom it's pretty much all red with just a small piece in the yellow......;
