look awesome man! Always thought orange builds looked fantastic.
Pretty snazzy looking motherboard.
The GPU backplates seem to match the Dominator colour perfectly.
En un seul mot : WOW !!!!
Did you try using a stepper bit to drill the holes or just a.regular bit? What type of material was it you were drilling again?
Gpus with the orange backplates look like a perfect combo for the rest.
A step bit would have worked great
I woulda used a stepper instead. Maybe try using it on the broken piece to see if it works? Sometimes if I have a material that slips a little like hard steel i'll use a really small drill bit to make a mark or a spot for the stepper to sit in nice.
funky:xentr_legal_notice_description
