Intel 14th gen review
Sigh. That's just BS. Intel is intentionally walled off the ability to use it on 13th gen to make 14th more attractive. Both are essentially the same CPU so in theory this should work with 13th may be even with 12th. So what exactly in 14th gen that this thing is relying on?
that's weird...it's abandoning their enthusiast crowd...odd.
I wouldn’t worry too much about that application. I wouldn’t personally use it anyway. I don’t need another application messing with my resources.
I run a clean system. Any time I can limit extra crap running in the background I take that route.
I used to be like that...but now that systems are so powerful and lots of RAM inexpensive, it's not so bad to have lil programs running in the background. so I totally get that...it makes for a much easier system to troubleshoot when you start having gremlins too!
