Yes JD you very likely told me to buy some and I got confused thinking the 90 degrees I bought were what you meant. I have also discovered that actually working with this stuff and having it in your hands finally starts to make things click and you start to see where and why you need different parts and pieces! At least that is how it is going for me. I read a tonne of stuff, your guys' answers to my questions, watched videos and only now am I starting to get all the intricacies.
And yes, thanks Bartacus; I'm pleased my butt is finally moving too! :haha:
So good suggestions! After fitting and figuring again tonight I am altering my plan. I was able to raise the pump/res a bit allowing me to square it up and get the out port above the shroud. I did it by just sliding it up in the holder a bit, maybe 5-8mm, so it'll still be secure I think once tightened.
I've also decided I'm not too keen on the big 90s everywhere, so I have gone back to just the small fittings and I am going to try and make it work with bends in the tubing. That is more the look I want and all chrome 90s was a bit overpowering I thought. The run between the front rad and the in port on the pump is still going to be tricky... I'll find out how tricky when I start bending!
I also puzzled and puzzled about routing down in behind the pump/res to get the drain in there somewhere and I just couldn't see a way to make it work. So I am changing to what you see in the pics below. Since the Bitspower drain piece I bought is small and looks nice, I'm not going to try and hide it. This is similar to what I saw a guy on reddit do with his build, so not taking credit for the idea. It still gets my drain point to nearly the lowest point in the loop, still looks good imo (appreciate to hear what you guys think) and I think cleans up the loop layout a fair bit. Also leaves me some more space underneath for cables.
Also cut my first piece of tubing and fitted it together. Cut it too short, the GPU was not secured where it should have been, so its a do-over but good experience! lol
On to the pics:
Adjusted position of the res/pump. I can still get the lid off the res... barely.
Updated position looking towards the front rad fitting. Tight bend... we'll see.
It'll end up being about a 45 degree bend to come from the out port to the three-way splitter, and I am hoping for it to run along, almost on, the shroud.
First cut and chamfered tube. Look OK?
And this is how the drain looks in place, the Bitspower drain fitting is on the left.
