Killswitch
I heard a few guys around here were curious to know how this build was going to turn out..... so here she is!!
I really liked working with this case. Very easy to make a clean looking rig with everything hiding in the back, which is also fairly tidy in this particular build (sorry I didn't take any picks of the other side :sad. There's tons of room to just bundle the cables and put a zip tie or two around them. Way easier than trying to keep everything semi-flattened out which sometimes tends to look messy no matter what the hell you do. :haha:
Overclocking the 4930K with the swiftech cooler was no problem. But the highest I could get without going stupid with the voltage in the few hours I played with it was 4.5 GHz @ 1.3V. All I did was bump the multi to 45, set LLC to "extreme" and CPU Current Capability to 130%. I'm not sure if those are optimal by any means but it was stable running prime95. For the ram I just simply set to it's XMP profile to run at 2400 MHz. Idle temp was about 32 celsius, under full load across all 6 cores/12 threads was 63 celsius. Pretty damn good IMO. unk:
I tried for 4.6 GHz but it wouldn't get to desktop without BSOD'ing even with 1.35V.
