- Location
- Grande Prairie, AB
So I replaced the electrolytic caps on the 100's crossovers. Still no tweeters. So had to the film caps, which I can't but from Digikey, etc. Hopefully Solen or some other audio shop stocks them. Won't be cheap tho.
Not sure how I didn't notice originally, but midrange on one of the 60's wasn't working. Pulled all drivers out as I assumed it was a cap on crossover. But there is so much foam in cabinet I can't find the crossover lol. So I measured continuity on mid. Nothing
. But I highly doubt they could burn voice coil on a mid so lol at driver. O thank heavens. No idea how this could happen but I'm thankful.
Also took off tweeter diaphragm in order to push out the cone. Not perfect but pretty close.
And now on to the NAD 2200. It would cut out at low volumes. For last couple months I've been using the the Aiyima A07 Max, which tbh is pretty damn awesome for size/price. But I'd like to get back to using the NAD. I suspect the issue is either the protection relays or a broken solder joint. Not seeing a broken solder joint anywhere do ill try the relays. They are known to fail, just generally not in this manner. White things at top.
Finding 40 year old replacements not always easy. There are a couple replacements that are similar tho. About $50 for a pair from Newark. They don't fit tho without some modding. Pins aren't the same size.
Had to drill out holes a bit.
Haven't done an actual test yet. But I've done a continuity test and they all seem to work.
Will test in a few days. Need to watch some vids to remind me how to set DC offset and bias to make sure the amp is calibrated correctly.
