New Kicking Build is on nigh!
Thanks and right back at you and a Happy New Year(everyone)!
So I got er done. I installed the latest Bios F31q and swapped out the 3700x with the 5950x. I'm thinking of getting Aida 64 in the near future to see what's what. I won't be selling the 3700x as It looks like my wife is good with updating our old desktop with the 3700x and a modest MB/RAM upgrade which is cool! It was her idea...ha
Cheers
Nice pic too btw! (y)
Hiya, so I'm a wee bit concerned/unknowing.
Yesterday the 5950x at idle running low 50'C and at @ 69'C during Aida 64 System Stability Test(24min run).
Ryzen Master shows peak voltage at 1.3-1.4 range and average core average @ 0.7.
Would you say the idle temps and voltages are a bit high? The stress temps and similar gaming temps don't bother me but the idle numbers do!
Is there an easy way to alter this situation......thoughts?
Oh and while in bios enabling XMP the CPU temperature was at 26'C.
Photo taken before XMP enabled.
Edit, added 2nd photo showing post XMP enabled after 20 min Aida 64 run...and tweeked the text, sorry.
I enabled XMP this morning and idle CPU temps while typing this is 57'C with voltages jumping between 1.2 - 1.4.
voltages are inaccurate in everything except ryzen master.
Okay, Rodger that. I'm 15 minutes into an aida64 system stability test and it shows voltage at approximately 1.1 where Ryzen Master shows voltage core average at 1.2. CPU temperature is 66 degrees Celsius and 64 degrees Celsius respectively.
I'm still after how I can get a lower idle temperature?
Do you have the fan on the AIO to exhaust out or in ? I find pulling cool air from outside the case works well.
dm1, yes I have the AIO drawing cool air in and I believe I did a good thermal paste application. The 3700x had good idle temps while I had it running.......I'm hoping some tweaking of a setting or two will lower my idle temps as under load temps seem quite fine. So many setting beyond my knowledge hence my call out for help!
Without getting into OCing yet (setting an offset will help) the most obvious "fix" would be to adjust your AIO's fan curve.
Thanks for the input fine people. Windows is set at balanced and I saw that 50c idle temps were acceptable but Aida 64 showing temp in high 50's panicked me...! Ryzen Master actually shows 51ish at idle. I might tweak my fan setting a bit but I prefer things on the quiet side.
