Let's go Team !!
BrainEater
Calgary
I believe they are the same length as the 260s, which are... hold on... ~10.5".
Ah ok , same as my 8800GTX.....cool......my case is fitted for the 8800GTX size.
I have thought about the proper order of upgrades.
First thing : new psu for my main rig. 1000 watt single rail...
:thumb:
Next : the 280/285 and hopefully an ATI 3850 too.....
Go Team go !
3.0charlie
Laval, QC
Single Client? Then you should leave the CPU slider at max.
Worst case, remove and re-install the Systray Client. Also, did you un-install the GPU drivers when you swapped cards?
Babrbarossa
New Brunswick
No- I figured that since they were both 200 series I could get away with just overwriting drivers. Will it not work if I did that?
Will reinstall now..
3.0charlie
Laval, QC
:thumb:
Go Team go !
errrr.. why do you need 1kW? What do you have in mind...
As for the PSU itself, OW at JG doesn't think it's that great:
3.0charlie
Laval, QC
I never take the chance, so I have no way to know if swapping card works... ake sure to use DriverCleaner in Safe Mode.
BrainEater
Calgary
I am looking into the 1kw psu's from several diff companies actually.
Switching powersupplies work best between 40 and 60 % load.The PFC , cooling , fan cycles etc are all best at this range.........So if I wanna run 2 high end folding cards/cpu etc , for my rig , 1 kW is more in line.....
:thumb:
3.0charlie
Laval, QC
A 850W can run dual 280s and an oc'ed Quad no problem... but if a 1kW is really what you want, I would take a look at either the Corsair HX1000W, or the Antec Quattro 1kW.
Also, there's a 3850 AGP on Fleabay for 100$US, brand new...
chrisk
Folding Captain
GTA, Ontario
If you want a 1KW PSU go for the Corsair 1000HX or the one I just got, the Enermax Revolution85+ 1050W (also a 950W and 850W available). The Enermax has up to 90% efficiency between 200W and 1000W (but is expensive, $300). The Corsair is a better value, and is almost as good (not as efficient).
LCB001
Aylmer QC.
I'm seeing the pausing in the display too. the performance indicator spikes and quickly drops to 0 - the time and graphics change along with it. And it's taking forever to to a unit.
It is highly recommended that you Do NOT use the display/viewer that comes with the systray client as it is known to slow down the client and/or cause system instability. If you haven't already I would increase the priority from 'Lowest Possible' to 'Slightly Higher' under the advanced tab to make sure the client gets enough CPU cycles...
