- Location
- Grande Prairie, AB
I assuming it has to be detecting current or something on that fuse. Not sure why.Could it be a voltage diff cause by extra device on the tap causing the CEL? Also, are you going to start blasting Taylor Swift as you drive around the hood?
Got my 3d printer working again yesterday. So printed out the new speaker adapters. Proud to say that all door skins fit now w/ speakers installed.
Pic w/ the front doors w/ the new speakers installed.
Had to take out rear seats / panels in order to run wires for the rear dash cam. Found a comment on a YT vid from someone who sound deadens vehicles for a job. He had suggested stuffing the rear 1/4 panels with foam. Since you can't really reach between inner and outer panels to apply the butyl. So I stuffed the snot out of them.
